Documents and Examples for S12(X) and S12 MagniV devices
S12(X)
S12 MagniV
DOCUMENTS
CAN setup calculator for S12(X) and MagniV devices
S12(X) MCU Security
S12(X) devices reference schematics
Useful documents for building own CAN bootloader
How-to Add missing derivatives to CodeWarrior Classic HCS12(X) 5.2 (Unofficial Method)
DOCUMENTS
S12Z constant, variable, code allocation in CodeWarrior
BLDC 6-step control speed scaling using S12ZVM
MagniV Power Dissipation Calculator
MTRCKTSBNZVM128 vs MTRCKTSPNZVM128 kit motor
S12ZVM configuration for the motor control applications
Software for S12ZVM motor control kits
DEVKIT-ZVL128 EVB review
S12 family devices - COP recognition consideration calculator
MagniV PLL calculator
Bus-Off Handling in MSCAN
EXAMPLES
CAN Standard ID and CAN Extended ID for S12(X) and MagniV devices, memories refreshment
S12XD, S12XE - External BUS design - Addendum To AN2708
S12X Examples Pack
TIC-S12-XDP512-FLASH-E_W-CW47
S12X_Interrupt_catcher (catch all unexpected interrupts)
API example code for S12G
Read paged const in S12
EXAMPLES
How to get device ID and write program once field without programming application to the S12Z device...
S12Z Protection Override
S12ZVC IFR Program Once Field
S12Z: Simulating ECC errors at EEPROM by cumulative write
S12Z: Simulating ECC errors at RAM by debug access
S12Z: Simulating ECC errors at Flash by cumulative write
S12Z SW example of COP Watchdog Reset
S12Z Interrupt catcher for unexpected interrupts
S12Z voltage measurement
S12Z EEPROM example code
S12Z Flash example code
Autonomous Clock Trimming SW example for MagniV devices
BATS Voltage Supply Sense example code for MagniV devices
High-Voltage Input (HVI) SW examples for MagniV devices
SW examples for MagniV S12ZVC and S12ZVL devices
PWM example code for S12ZVL
S12ZVL-TIM-FrequencyMeasurement-V1_0-CW106-TIC-EXAMPLE
SW example of Security feature with Backdoor Access Key option for S12ZVL
Example S12ZVL ADC0 triggered by TIM0 OC updates PWM duty cycle
S12ZVM clock module and PLL configuration - SW examples
Low power mode example code for S12ZVC
Single / double bit RAM ECC error example code at S12ZVC
S12ZVML-MINIBRD software ported from AN5327
Example: S12ZVC192-ACMP-POT-CW107
Example codes form "Easily Develop LIN-based Actuator Applications with Mixed-signal MCUs" webinar
100% helpful (1/1)
Version history
Last update:
‎06-02-2021 06:28 AM
Updated by:
